This kit (cheaper at walmart or amazon), a pair of needle nose pliers (or screw driver), a utility knife to shave down plug and an air compressor and you can be fixes in 15 min for under $10.
Too late. Should come tomorrow by Fedex, at least fast shipping. Canāt drive around on this tire without spare, really.
I think my screw is in the borderline area:
Iāve been plugging tires for years. Never had any issues. Iāve plugged a tire in my driveway without even removing the wheel. You do have to have an air compressor or even a bicycle pump.
The one time I didnāt have a compressor, I had to put on the spare and drive to a gas station. Plugged the tire in the gas station lot.
The not having to take the tire off the wheel is the best part of plugging the tire. Pull nail out, ream hole, insert plug, trim plug, fill tire with air.
I had 2 run-flat tires repaired at my local Goodyear tire shop, both nails/screws along central tread area. Assuming the tire is repairable, I think itās down to the tire shops policy, i.e. are they actively looking to maximise tire sales at the risk of annoying customers.
Run flat tires seem misleading as an interior shot of one looks like they have some sort of bumper ring on the wheel to keep it from ruining the wheel itself while you drive it somewhere safe. No idea why they wouldnāt be pluggable.
So, I got the tire - it was patched and the puncture was actually even closer to the sidewall than on mine. Took it to Costco, the guy looked at mine and the replacement tire and said they would not repair mine but would install the replacement. Then mechanic comes out with my tire and tells me he can fix it, no problem, and that the replacement tire is garbage in much worse condition than my tire and it should be returned. So, Costco fixed it for $15 and I then contacted bestusedtires. Sent them pictures and RMA repair guidelines. Within 30 minutes they issued the full refund and told me to dispose of their tire any way I want.
Yep. But I guess itās expected when they resell discarded tires. A set of 4 or 2 used may be perfectly fine and without repairs when someone just buys new tires. A single tire must be after repairs and if it was discarded, then it was probably oficially unrepairable in the first place. These guys say:
SOME of our tires have been professionally repaired (safe spots only, this means no sidewall repairs).
OK - could use some advice here. Wifeās X1 has Pirelli Cinturato RFTs that are down to 3/32. They are driving like absolute garbage. Almost 22k miles on it with 13k remaining miles allowed on the lease. Goes back January 2020 and Iām expecting 7500-10k miles more before it goes back.
Iām OK with the used tire approach for lease returns, but not super keen on it when she needs to drive on them for the next 12 months.
Any thoughts or suggestions? The OE Pirellis are a fortune (and ride horribly). Iāve seen the Bridgestone DriveGuards but they arenāt well regarded either.
I suppose I could just transfer the lease and get a new car - give up some of the MSD on it in return for letting them deal with the tiresā¦
Why would you not want used tires if she has to drive on them? As long as they have the proper tread, and havenāt been abused, Iād never have problems with a tire that wasnāt new. You are going to pay a huge premium for new tires or transferring a lease with terrible tires. If you just donāt want to deal with tires in general, I guess thatās understandable, but there isnāt much too it if you have a reputable source and a good tire store to do the install.
The only source I have is bestusedtires (mentioned here) but Iāve seen a lot of bad stories (including here) about patched or repaired tires. That is generally OK, but my understanding is that patched RFTs are not good.
You definitely donāt want patched run-flats. Iāve had good luck with bestusedtires. I had one with a patch, and they shipped me another tire at their expense. They are pretty easy to work with.
I donāt think you are missing anything. Iām just going with my personal experience with them. Iāve ordered tires from them that were just for lease turn-ins and ones that Iāve driven on for months before the end of the lease. Iāve only had one ābadā tire, and they replaced it without a hassle. Your experience might differ, and I completely understand.
