There weren’t 4k brand new 4xe’s on dealer lots or high interest rates last year.
That’s definitely new, I haven’t seen so many dealers with stock or incoming since this all started.
Thanks for the reply! It’s also what I believe is causing the issue. The gas cap has never felt right since day 1 on this vehicle. It’s weird to have it happen now.
Oh wow - you’re right - I check cars.com every now and then for NEW 4xes for almost a year. It’s always been 1500-1800 when I’ve checked - right now it’s 4,100! I think if dealers can’t sell them all by year end there will really be a glut when the credit goes away.
Once the credit is gone, the party is over for sure.
Any MMR for 23s yet? Sahara?
I used both my Tread Lightly codes… signed up with a different e-mail a couple of days ago-will see if it works on the 2023 Purple Reign 4Xe and the Charger HC… if not, well $100 to a good cause I have a feeling the HC won’t get here by year end, so my first TL expires Jan 2023 may be able to use again if it gets delivered in 2023
Agreed. Money to TL is put to a great cause.
Which dealer is offering the best discounts on HCs or Scat Packs these days?
All signs point to yes
But if it’s the same thing no double dipping ?
And don’t forget if you’re married you can use a spouses tread lightly/affiliate.
So October rates out on Monday or Tuesday.
Have a feeling they might get bumped up a little bit on MF. RV and ACQ might stay same as current.
Does your spouse have to be in the lease also?
Does this apply if I already used two codes from tread lightly this year?
You can be on the lease. When I used my wife’s code with Gupton they needed the marriage certificate
Have you really double dipped if you use the other hand/side and nobody saw you asking for a friend
@xmonger Try @Clutch for west/south or any of the east coast brokers/dealers,
Mine, can’t wait to see how terrible the offers are in 3 months, but it is purple which I gather cannot be ordered anymore.
Reign is still available to order as far as i know, but it is a limited time color, so that will change.
Thought I saw somewhere October 1st was the last day to order it, could be wrong.
Its possible thats true. I havent seen any orders discussed in the last 24 hours to say one way or the other.
I’m not sure what the cutoff is but pretty sure it’s October, thought it was early but doesn’t matter. I don’t care either way, I’m out after this one, keeping it for a bit but no more for me.
It really is a sharp color, if I could go back to 21 and score this for 400 a month, I would def just let it sit in the driveway.
Had a similar issue with mine, went on after a stop at the gas station. Figured that’s all it was but the check engine light never went off even after checking the cap and driving over 100 miles. Took it in recently and was told that the fuel tank isolation valve (FTIV) was stuck open. They ordered the leak detection canister which is backordered, of course.
