So recently i noticed this. Ezpass transponder would not work on vehicles with heater front windshield.
Did anyone of you notice this? Any tricks to make it work with heated windshield?
I called ezpass nj and they told me some land rover vehicles have this problem and i would need the plate mounted transponder to make it work.
Thanks.
looks like you have your answer
Yes but i don’t want to drive around with the plate mounted transponder hanging like that lol. So that y i asked opinions.
put it on a selfie stick and poke it out of the sunroof
Put it in a small bag with a suction holder and stick it to the bottom of the windshield.
Usually Ezpass would cross check your transponder ID, license plate and will directly charge your ez-pass if not recognized at the toll.
Check the owners manual. There may be a section of the windshield that is non-infrared that would allow the transponder to still work.
pter
April 12, 2019, 12:27am
7
Curious what happens when you have the ezpass registered to you vehicles plates, but it doesn’t read through the transponder?
I ask because in CA, we have Fasttrak and the systems cameras will recognize the plate, this avoiding a ticket.
Perfect, found out that it can be placed behind the dot matrix pattern on top of the windshield. Thanks
yes in NJ too, if the transponder doesn’t gets recognized, they will charge by plates, but if your plates aren’t registered with ezpass, they will send you a $50 fine i guess.
mllcb42
Split this topic
March 9, 2021, 12:41pm
10
A post was merged into an existing topic: Off Topic Landfill 4
mllcb42
Split this topic
March 9, 2021, 2:04pm
11
