Advice / help with issue with broker deal
Nationwide.
Advice /help needed.
Was dealing with a broker @arkautomall I found on the platform, Thursday night to close a deal on a QX60.
Got the deal in writing and via calculator.
Friday morning submitted credit app.
Broker comes back and says the programs changed overnight night and they no longer have a $1000 incentive on the Qx60 in my zip code. Price will be higher overall.
Just checked calculator it says incentive goes to 9/30. Maybe it’s wrong? Not updated.
In brokers defense he called me to explain, stated he would not do anything to make it right. Take it or leave it approach.
can someone check if programs really changed on the model over night Thursday?
All this has been really odd, left a bad taste.
Dealt with brokers before never experienced an over night instant program change without any heads up
[Since you are a Super Supporter, you can use Ratefindr to check if there is currently any incentive, although it won’t tell you if tjere was one earlier in the month
You can also check the pertinent Edmunds forum to compare incentive from now vs earlier in the month. Since you are a Super Supporter, you can use Ratefindr to check if there is currently any incentive, although it won’t tell you if tjere was one earlier in the month
You can also check the pertinent Edmunds forum to compare incentive from now vs earlier in the month.]
Edit: I can’t get the strike function to work properly. Ignore what I wrote above. I just noticed that you already said you had used Ratefindr. If you provide the needed info to aronchi, let’s see if can help you to figure out what’s going on.
that’s not a broker. that’s a dealer. where are you based? i can vinzip the car for you.
I have no clue if it happened in this circumstance, but it does happen on rare occasion. If the bank pulled a surprise incentive change, there really isn’t anything they can do about it.
@arkautomall is a dealer on here, not a broker. Are you sure they said an incentive went away? It seems like they pulled back on their discount, according to this post.
Here we go again…
Not saying that is the case here, but LHer seems to be seeing more and more of these types of posts.
I feel like there needs be some sort of sticky that states/suggests the customer should go through some informal process with the broker/dealer to ensure that what they think is a “wrong” is actually a wrong before posting all of this.
Thank you Was attmpting to register in 48188 or 43551
what was the amount of lease cash quoted?
If the dealer decided to raise the price or lower their dealer discount amount then that is different than telling someone Infiniti FS changed the program mid-month. Why not just say that? Especially if you already quoted someone and ran their credit.
If IFS had a mid-month program change then perhaps it’ll show up on RateFinder / Edmunds sometime next week. It’d be nice if the dealer could just post a screenshot of the communication from IFS verifying this.
I’m just stating my experience and not pointing fingers.
I’ve dealt with brokers here on the forum a few times and have had smooth transactions. I did my due diligence checked rates and incentives on rate finder etc.
Looking for advice and feedback. Not to start a passive aggressive back and forth.
The amount was $1000
that’s right.
Gotcha, they stated it’s no longer offered overnight, which is the point of my concern.
ok so you were lied to.
Right, like I said:
Dealer’s username does not check out
As a broker I’d eat it. But as a dealer he’s prob a sales guy, not sure he can. But I’d take it up with management over a bad review
Not sure I’d say he’s lying. He said programs not incentives. I guess a program could be his internal ones
um all this guy did in text is show us bunch of screenshots of other dealer invenotory pricings etc. either from michigan or ohio he wants to register this car in, there’s no rebate available for him.
Did you inform the OP that the programs had changed overnight?
yes we did via text.
23b4e8ab-d2fe-4e36-afa6-e2bdaa4bbab5.pdf (33.5 KB)
