Hi, I am curious to know how dealer’s quote will be less than lease calculator numbers.
I got this quote from Hyndai dealer in Nashua, NH. My address is in MA.
When I put same numbers in Lease Calculator (link below) and keep MF “as is”, number is coming higher than dealer’s quote. I assume dealer won’t charge lower MF than what I see in Rate Finder.
I am just curious to know what may be the reason so I can negotiate with correct numbers..
They might be using slightly higher residual. I’ve seen that with Honda LH residual sometimes doesnt match dealers quotes maybe its the same here
Thank you for sharing this..
I will confirm with the dealer..
Thanks!
You can check Edmunds lease forums too…also spend time researching what an aggressive discount off MSRP should be for this SUV…1600 seems a little light…search for that model here or look in Marketplace.
You are putting down $695 plus the first payment of $695 for total due at signing of $1380. Then numbers match exactly.
Also, rebates are not taxed in Massachusetts.
That shouldn’t be the case, if the dealer is using Honda Financial. Do you recall when and what the discrepancies were?
The dealer quoted my friend a Prologue, residual across the trims was about 9% higher on the quotes compared to the calculator, assuming they were using Honda Financial because they were adding the captive lease offer.
If you didn’t let us know at the time, please do so in the future so that support can reach out to the data provider.
Yes I didn’t negotiate yet. Just go the first quote and it seemed lower than calculator. Thanks for the suggestion though!
This 695 as per sales guy, was the first month payment. But he might have made it up and as you said he might be expecting 695 + 1st month. Will clarify in past week of the month.. thank you!
