I am returning my Mercedes c300 lease but 5 days before my return I got a check engine light appear. I took it to the shop they wiped the code but it reappeared after 30 minutes and after inspection, he found one of the pieces of the engine needed replacing(I forgot the name of the part). He said it would be $200 to fix but I’m wondering if the engine is covered under my lease warranty and would I be charged for the Engine if it is and I don’t repair it before returning the lease.
Please advise, do you think there will be a charge? if so should I go to the Mercedes service center, would they charge? Or should I go to my local mechanic to fix it?
What code is it and what is the repair? New sensor or filter? $200 to have anything done on a Mercedes is in the low side. Let’s make sure this isn’t a $50 sensor & a YouTube tutorial type fix before going to far down a rabbit hole.
This is my thought also. The car was leased as a loaner. But I’m way under 50k miles. And haven’t hit the 4 years. I thought engines are covered under the warranty.
I will get the code tomorrow and provide it here.
Does Mercedes charge just to check even if it is a lease?
AutoZone, Pep Boys, Oreilly’s etc…will let you use a scanner in their parking lot. Then Google whatever the code is and that should get you pointed in the right direction.
Doesnt matter how long you have had it. How long has it been since the warranty in service date? With loaners, the warranty clock starts ticking before you get it.
Yes, if you read your lease agreement and turn-in documents, it will say no error lights (or something to that effect) on return.
The charge can be significant, depending on the issue, and that’s why you’d want to make sure everything is ok (or meets expectations) at turn-in.
I turned in my BMW with warning lights on, didn’t get charged. Dealer probably happy they got paid for Parts and labor also. YMMV but if you didn’t mod the car or do anything outrageous, you should be ok
Don’t waste your time going anywhere but a Mercedes dealership. Your warranty covers virtually anything mechanical aside from your negligence or damage for the length of the warranty. Being a lease doesn’t change anything.
