I’m returning a 2019 Honda Civic LX in 5 days. Just my luck–one of the tires went flat today, and it’s probably irreparable.
If I return the car in this condition, how much should I expect to be charged for a replacement tire? Will the dealer charge so much that I should go through the hassle of replacing it myself? (With some minor dings, I’m already over the $500 damage waiver.)
Did you check if you have equity before just turning the car in?
Most likely you will be charged the full rate for a replacement tire and labor so probably in the 2-400$ range for a same exact matching tire depending on the size.
How important is it to match the brand of the remaining tires? The lease agreement is silent on that issue; it just says the tires have to be in working order with sufficient tread.
