Calculator Problem
Is anyone else having a problem with the calculator? It is not loading the jeep trims for some reason? I’ve tried refreshing and using different browsers.
I’ve asked “upper admin” if/how to address the issue (and am awaiting a response).
Someone else was having an issue with 2026 Land Rover data which makes me think it may be a data provider issue or some data hasn’t fully pushed through the system yet.
Run Google Chrome developer tools and see what’s failing to load?
Paging @littleviolette
Thank you for flagging this!
We have been seeing periodic issues where data is not getting refreshed or populated fully. We will reach out to our data provider to understand more. I also wonder if they were in the middle of pushing out the data as @ApexHunt noted above.
I just tried pulling the Jeep Wrangler trims – they are showing up now.
I think the calculator/rate finder is still having issues, as it’s not able to pull all the current Audi models. The screenshot below shows that the dropdown does not list the Q7, a very popular current Audi model. Is there a known issue?
I just tried pulling the Audi models again and Q7 is now showing.
We have reported the issue to our data provider. They weren’t able to replicate the issue at the time but they said they will investigate further. I will add this to our example. Thank you for reporting it!
