There’s no pull-ahead so the (presumed negative) is going somewhere. You need to separate the deal and assess that.
I’m not following the presentation here. I assume the term on the “breakdown” line isn’t intended and these are 36/39 month payments with either $5000 or $7500 DAS?
Why are we ejecting a year early from the current lease?
You were marketed-to and you have our permission to ignore that and keep driving your current X3.
If you want out of the current one you have the option transfer it, or compare the payoff to ACV and see how big a hole you need to dig to bury the negative equity.
8 posts re a BMW and Swapalease hasn’t come up yet? Apple Cider Vinegar is not normally the first choice in those situations unless the deal is giving you real heartburn.
OP, thoroughly research potential issues with frozen colors if all else makes sense.
This is not a “swap.” You are trading in your current vehicle to the dealer and any negative equity that is in your current vehicle is being “swapped” into the new lease. That’s the swap.
