Hey guys, anyone have a fix for wireless CarPlay when it’s giving you wrong directions? I took delivery of an Acura ZDX and I can’t use Apple Maps or google maps because it tells me to go the wrong way. Even the speed limit is off in google maps if it does work (rarely). Nothing on google has helped me so I might need a service appt
Try using waze
Is it also happening when CarPlay is connected with the wire?
this sounds more like you have precise location turned off or something is accidentally turned off in system settings.
go to settings–>privacy–>location services and check that everything for apple maps/google maps/system services is turned on. map apps need “precise location” turned on to work correctly.
edit: also does the built-in acura navigation work normally?
What do you mean the wrong way? Like says turn left instead of right?
I will need to look into how to use the wire. Right now it’s set up to use wirelessly and connects immediately
Yeah it’s really annoying
Same thing
I just tried this and it’s set up correctly. The built in nav says I need a subscription (it was a loaner)
Im surprised that GM allows that even on a rebadge
