Have you considered 2021- the will have a higher RV and probably more incentives- check with Edmunds. May be less than 2020 0and newer MY.
Post a LH calculator so that you will understand how your deal is structured and can easily manipulate the variables. You will likely get more feedback as well- here to add insight, but not to do your research.
I don’t think so – after speaking to the dealer he just mentioned the vehicle being discounted from 55490 to 47000. Edmunds also mentioned there were no incentives.
The fees included in the Adjusted Cap Cost are: Acq. + Doc + Gov + License
I have considered the 2021. These are the numbers I got from Edmunds for 36mo/12k:
MF: .00120
RV: 55%
No incentives
The reason I was considering the 2020 was because it was well spec’ed out and had more discount on the MSRP than a comparatively spec’ed 2021. Maybe I need to do more research…
