If you go the private party route, I strongly suggest having a professional boat appraisal and inspection done. It’s $200-$300 well spent, as it will also give you an idea of what maintenance or repairs will be immediately needed. There are almost always maintenance or repairs immediately needed, otherwise the private party wouldn’t be selling.
The most important thing, IMO, is the construction and condition of the transom. Once the transom rots out the boat is basically worthless. This is obviously crucial with an outboard, but even with an inboard you have many critical systems depending on the transom. Modern boats will have re-enforced transoms engineered beyond the strength of the rest of the hull.
The second most important thing is the rest of the hull. Make sure the bilge stays dry, otherwise you have leaks. Check all 4 corners of the hull, as these are first point of contacts with the dock structure. Check the bottom of the hull, ideally out of water, or if not with a scuba rig. If your in saltwater you will probably need a painted hull bottom, make sure it’s scraped clean and the paint is in good condition. If it’s not painted, get it painted. Check all the hatches, windows, seals and other points where the hull material changes, especially to wood. Make sure all the ties downs are secure, as well as ladders and any outrigging.
Then, the engine. Modern boats use all electric engines now and, just like a car, you need a diagnostic computer to troubleshoot them. Older boat motors will still be run on carburetors and throttle cables, personally I wouldn’t mess with that old stuff anymore, but if you are a gearhead you may like it and want an older powertrain. Make sure the engine doesn’t have any leaks at the critical seals and that it makes good power and can get the boat onto plane quickly. Make sure to check the outdrive and propeller, at least visually for damage or scrapes. These get damaged first if you run the boat aground
Finally, all the electric systems, Throttle, trim, GPS, engine systems, boat systems. Everything should be tested to make sure it works. You don’t want to get out to sea and realize your forward bilge has failed. Make sure the batteries are newer and the charging systems works. I don’t go out without at least 1 backup battery. I recommend a solar charger and a shore hookup.
After you test drive, pull the drain plug and see how much water remains. Make sure you put the drain plug back in
Don’t forget to inspect the trailer. Needs to have at least surge brakes in this day and age. I am an old salty northeastener but I suspect most of this applies to you guys out west.
