Last service on the assumption we did was last august, so less than 1 year ago and also less than 10k.
Oil service shows open, but I have the dealer invoice for when that was done so assume I should be good.
However in the car and when running the key it shows
Brake fluid
Vehicle check
were due (and I do not see those listed on the last service). Any ideas of average cost for these? Once all is resolved and pre inspection show nothing, I’d turn it in right away, can they charge anything after the fact in case they did not check etc?
It is not low, it just says scheduled service was due for:
Oil change (have invoice showing it was done)
Brake fluid and vehicle check whatever that entails …
I tried looking on youtube but those did not work to reset the reminder, not sure if that only works if service will be due and not if it was already missed !?
Yes, I will give another approach read a try, as long as another dealership does not check with the key in the system may be ok, if so will turn in on spot if possible to not take any chances.
As I am not the original owner with free ultra care, does that mean I could also just get the brake fluid changed somewhere cheaper and bring the invoice with me, and worst case how much would you expect at BMW (online estimates list ~$200, of course trying to avoid that)
It’s around 30k I believe. While it seems a bit early, brake fluid changes aren’t a bad thing. That stuff goes bad over time, collects moisture/water, etc.
You can take it to any reputable shop. Maintenance doesn’t have to be done at a BMW dealer, especially if it’s coming out of your pocket. Only reason to go to a BMW dealer is if the maintenance is paid for/free.
