The 330e has a 12 kWh battery with only 9 kWh useable, so if it’s taking you 3 hours, you’re charging at around 3 kW. That’s awfully low. May be a limitation of the on-board charger though, as the ratings I’ve seen call out charging speeds based on a 240v/16amp charger which is lower than any level 2 charger I’ve seen
Mine gets 20 - 25 daily. Drove 2500 miles on pure electric already. The predictometer is quite variable and I largely ignore it now since it’s usually understated.
If you really want to meet or exceed the 21 miles of rated electric range:
Drive efficiently. You’ll get the best range in ideal weather conditions and by staying on roads that are between 35mph-55mph.
Be mindful of climate. Turning off A/C or using the minimum setting goes a long way. Open the moonroof instead or pre-condition beforehand if possible.
That’s pretty much all there is to it.
If you’re only getting 10 miles of electric range you’re either blasting the A/C, in an extreme climate, and/or taking the electric drive on the highway where it won’t be at its most efficient. When using navigation on the Auto eDrive setting the car will automatically switch between the engine and the electric motor to maximize range.
I think several of the electric only cars charge to 80% in under 20 minutes. So they can probably get 150 miles at least in that time and bmw only does 20 miles in 3 hours. That feels wrong…
Framed that way, I agree. But I’m smitten with BMW so they can do not wrong
EV/battery/charging technology is evolving so fast, none of this will matter soon. I’m just wondering where I’ll get (cheap) gas from in 20 years for my manual transmission ICE guzzlers.
This requires you to be hooked up to a DC fast charger at 150 kW+. I don’t know of any phevs that can charge at a DC fast charger.
The rate of charge here for an L2 charger is still quite low, but I bet that the limiting factor is the on-board charger not the station.
There really isn’t much need for most phevs to charge faster than that. If you’re traveling long distances (where an ev needs a DC fast charger), you just fill up with gas. The 20 mile electric range doesn’t do much. Instead, it’s about plugging in at night for your daily commute. If it’s charging overnight while you sleep, what’s the difference between 3 hours and 1.5 hours?
Ah now I get it. So the car has to be certified for fast charging.
I haven’t done the charging overnight at our place. I don’t want to hijack the thread - the garage has a dryer outlet (10-30) and depending on who you believe online it might help charge the battery faster or fry it. Working on finding a better solution.
It’s definitely not as beneficial or effective. On a level 2 charger you might get 100-150 miles of range on a BEV in two hours, whereas on a PHEV such as this you’re lucky to get 20 miles. It’s almost a waste to even use a charger when out if there are other fully electric vehicles that could be charging instead.
There are a lot of variables that can affect efficiency in a PHEV. I find that in a PHEV even more so than a BEV you have to be mindful to achieve the rated range.
Try minimizing or even disabling the A/C (use the moonroof), stick to city roads, and maximize regenerative braking. Figure out your mileage then. If you’re not getting 21+ miles in Max eDrive then you have a problem.
Getting half the range isn’t surprising if you’re not already maximizing efficiency. If I blast the A/C in my 2018 330e the range also drops to nearly half.
I just played around in the car settings and see the default for charging is set at the lowest number 6 amps. Do you all increase that whenever you pull up to a ChargePoint etc?
