my experience with Sonata pricing is that you can get 7-12% off msrp BEFORE any incentives. Higher trims put you in the 10-12% range; SE trim level is 7-8%. Of course, supply/demand and market timing are also factors.
Okay, so I’m a little too optimistic with the 14%. I’m seeing $236 on Honcker but that probably doesn’t include the Tech Pkg option. $260/mo on $26K is probably the best I’ll be able to do?
if you are ONLY using the HMA tool, it is not updated with all the PLUS models. You have to go to dealer sites to view actual inventory. I would be very surprised if there were NO plus models in SoCal…GL
Even the dealer site doesn’t distinguish “plus” in Limited trim. Window sticker does show the “Tech Pkg” options included. So this is what I’m offered on 3-year 12K lease with $0 drive off, $311 per month including tax.
Yeah, it’s 11% off MSRP. And reportedly some of the numbers I had were off. MF is 0.00207 acquisition fee $650, registration $512. If I pay the drive off charges, it comes out to $250 before taxes.
I believe that the Limited 2.0T is the exact same as the Limited 2.4l “+” with the tech and ultimate packages except for the upgraded engine.
There were previously some other styling differences, but the new Limited 2.4 “+” has those anyway. (I’m putting “+” in quotes because it isn’t called the “+” as was discussed above, but it is refreshed… it is confusing).
You should be able to get $5000 in incentives. Are you looking at the 2.4l Limited with tech or 2.4l Limited with tech AND ultimate?
Couple of things: as mentioned, acq fee is now $650, registration fee is $650 and the MF is 0.00207. And you have the incentive as non-taxable, I thought cap reductions are taxable. Other than that, our numbers are very close.
